Message 1 of 4
BT address mix up has led to me being disconnected
Having an absolute nightmare with BT , cannot get any resolution, have been without broadband for a week due to my neighbours moving in to next door property and their address mixed up with mine so BT think I’m moving next door ! No one seems to be able to help and I’m getting more and more frustrated. They have taken my direct debit yesterday for an account that isn’t even active ! Can’t get through to anyone on phone.
3 REPLIES 3
Message 2 of 4
Re: BT address mix up has led to me being disconnected
Perhaps you can clarify the issue , first , are BT your  provider, or do you think it’s BT’s responsibility to sort it out regardless of the actual provider ?  ,
if your neighbour (new neighbour presumably that’s recently moved in ) put your address on their application for service, you should have received a communication from your provider saying something along the lines of ‘sorry you are leaving’ , did you get anything like that ? ,
who is your neighbours provider ?
if your address were incorrectly used by your new  neighbour, then you would expect their service to be now ‘live’ at your address (even if you can’t use it ) and them to have no service at their address , because it was incorrectly supplied to your address , is that the case ?
Is it understandable why someone could mix up your address and their address, like they have the same house number but different suffix, like 1A and 1B , or are they very  different although likely to have the same street name , perhaps you can give the first part of your address and their address , obviously don’t provide any personal information.
Message 3 of 4
Yes basically the internal ONT fibre box in my house has the incorrect UPRN but getting this changed seems to be beyond anyone’s capabilities. I keep being told it’s openreach I need to contact and then openreach tell me it’s my ISP
Message 4 of 4
as openreach do not deal with the public it is your ISP who you need to contact and get it sorted.  when you call make sure you have the S/N of the ONT
