Message 1 of 5
Changing to Fibre - IP address options?
Hi there and sorry if this question has been asked and answered - I have searched through the history but could not find the answer I am looking for.
We are looking to move to Fibre and would like to stay with BT if possible but I need to know if Community Gateway NATing is the only option provided by BT or do they also offer a Static internet facing IP Address option?
We would need the latter...any advice would be most welcome
Tags (1)
4 REPLIES 4
Message 2 of 5
Re: Changing to Fibre - IP address options?
As far as I know, they have never offered a static IP to domestic customers.
Are you a business customer by any chance?  If so, you would be better posting here:
https://business.forums.bt.com/
Message 3 of 5
Yep, static addresses are only available to business customers.
Message 4 of 5
In fact, I've never heard of "Community Gateway NAT".  Are you sure you don't mean Carrier Grade NAT (CGNAT or CGN)?
If it is the latter, again as far as I know, BT do not use CGNAT
Message 5 of 5
Just to clarify, for residential customers,  BT do not offer static IP addresses neither do they employ CGNAT, they employ dynamic IP addressing in line with most ISPs.
