Message 1 of 3
BT hub has started having issues
I switched over to Bt over a month ago and have had no issues but all of a sudden my wifi has stopped working completely. The lights on the box are going solid blue for a couple of seconds then flashing purple then flashing orange and repeating these steps. I have tried resetting and turning it off but nothing is working. Pls help
Tags (2)
2 REPLIES 2
Message 2 of 3
Re: BT hub has started having issues
your wifi is dropping because your hub is losing internet connection hence the colour changes
check you have a dial tone  and then dial 17070 option 2 should be silent - no applicable if you have digital voice
check you connections - are you connecting to the master phone socket or a small openreach fibre modem ONT?
Message 3 of 3
Hi @Dmc19 and welcome to our community.
Sorry you're having a few problems with your connection. Can you please try the advice posted by @imjolly and get back to us?
Cheers
David
