Message 1 of 6
Braodband fault
I am away from home and I'm unable to access some connected services via BT Broadband.
It seems to be impossible to rise a fault at the moment and the system tells me it isn't working.
Any ideas? Does BT have a major outage today?
5 REPLIES 5
Message 2 of 6
Re: Braodband fault
Hi @PeterR
I'm not aware of any overnight issues. Are you still having these issues this morning? Which connected services are you trying to access?
Chris
Message 3 of 6
Re: Braodband fault
Hello Chris G
Yes - PoP 3 has ceased to function this week......very frustrating - can yu offer any guidance.
John E
Message 4 of 6
Re: Braodband fault
@jfkyachts Why are you posting on this totally unrelated thread when I moved your original post to the appropriate board?
Message 5 of 6
Re: Braodband fault
My apologies - it seemed to me, it is all part of the same problem? I will try and avoid this.
Message 6 of 6
Re: Braodband fault
We had similar issues earlier but managed to resolve it.
