Message 1 of 21
Broadband Drops 30+ Times per day, multiple engineer visits please help
Hi, Just pasting my router stats before anything else.
My broadband has been dropping out since September, and it's been getting progressively worse. (Sometimes 20+ in 1hour in the evenings) I've had several engineers, including 2 open reach engineers who could not find anything wrong when they run there tests. My Smart hub 2 is plugged directly into master socket.
The last Engineer suggested a new router because he thinks there is interference with the Router. I've had the new Smart Hub2 for few weeks and it's still dropping. Some days it can be totally fine, maybe 1-2 drops. Then others it's probably 50+.
The cabinet is basically outside my drive as well so I am very close. Both Engineers said they checked things at the cabinet as well and saw nothing out of the ordinary.
EDIT: It's currently dropping as i wrote this. Managed to capture the following, then it dropped again. Look at the Noise Margin
20 REPLIES 20
Message 2 of 21
Re: Broadband Drops 30+ Times per day, multiple engineer visits please help
What happens if you use the test socket (remove front of master socket to reveal)?
Message 3 of 21
@marklong
Welcome to this user forum for BT Retail phone and broadband customers.
Is the home hub rebooting or just disconnecting?
Its possible for your home network configuration to cause the home hub to reboot or disconnect.
What devices do you have connected to the Ethernet ports on the home hub, are you using any powerline devices?
Look at the event log and see if you can see anything that may be causing this. LAN Up/down messages can indicate issues.
There were also reported issues on some home hubs which were caused by excessive uploads.
Do you know whether the hub disconnects when there are no connected devices?
Also try the test socket as @pippincp  suggests, as there are known issues with the NTE5C.
Message 4 of 21
Dropped again whilst i tried respond.
I was already running directly into test socket (without the face plate). After first engineer visit, he put a new socket on with a face plate. But i've removed it again to plug directly into the test socket to see if it stabalises.
Message 5 of 21
As I enquired, what do you have connected to the home hub?
Are you using any powerline devices?
Message 6 of 21
Log below from Events when i last disconnected.
But to answer what i have connected,  Nothing fancy, No PoE, Just a few phones and ipads on 5GHZ, 1 Desktop via Ethernet and a TV also on 5G i think
19:19:50 02 Jan. 2.4G Client associate from 82:21:9c:c6:ed:49 (IP=192.168.1.243) RSSI=-46
19:19:50 02 Jan. LAN [ADD] ARP 192.168.1.243 with 82:21:9c:c6:ed:49 from br0(wl1)
19:19:50 02 Jan. Receive a DHCP request
19:19:50 02 Jan. WHW INFO A station (SmartHub2)IF[2.4G](64:CC:22:05:32:D0):STA(82:21:9C:C6:ED:49)(Legacy Device) join WHW infrastructure
19:19:46 02 Jan. DHCP device Disconnected: 192.168.1.243
19:19:46 02 Jan. LAN [DEL] ARP 192.168.1.243 with 82:21:9c:c6:ed:49 from br0
19:19:46 02 Jan. 5G Client disassociate from 82:21:9c:c6:ed:49  (IP=192.168.1.243) RSSI=0
19:19:46 02 Jan. WHW INFO A station STA(82:21:9C:C6:ED:49) leave WHW infrastructure
19:18:45 02 Jan. SIP WAN DOWN
19:18:36 02 Jan. SIP WAN DOWN
19:18:36 02 Jan. WAN Sensing Auto sensing Complete
19:18:36 02 Jan. WAN Sensing Auto sensing Running
19:18:34 02 Jan. WAN Sensing Auto sensing Complete
19:18:34 02 Jan. WAN Sensing Auto sensing Running
19:18:34 02 Jan. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
19:18:33 02 Jan. PPP: Stopped PPP daemon(0
19:18:33 02 Jan. PPP LCP Send Termination Request (User request)
19:18:33 02 Jan. PPP: IPCP down
19:18:33 02 Jan. PPP: LCP down
19:18:33 02 Jan. DSL Link Down: duration was 51 seconds
19:18:25 02 Jan. NTP synchronization success
19:18:25 02 Jan. NTP Server: ntp.homehub.btopenworld.com
19:18:18 02 Jan. LTE Modem owl_tx_lte_set_rate_shaper_script command sent
19:18:17 02 Jan. LTE Modem owl_tx_lte_set_rate_shaper_script command sent
19:18:16 02 Jan. DHCP device Connected: 192.168.1.243
19:18:15 02 Jan. WAN Sensing Auto sensing Complete
19:18:15 02 Jan. LAN [ADD] ARP 192.168.1.243 with 82:21:9c:c6:ed:49 from br0(wl0)
19:18:15 02 Jan. ARP [add] br0(wl0) 192.168.1.243 82:21:9c:c6:ed:49
19:18:12 02 Jan. WAN Sensing Auto sensing Running
19:18:12 02 Jan. DHCP device Disconnected: 192.168.1.243
19:18:11 02 Jan. LAN [DEL] ARP 192.168.1.243 with 82:21:9c:c6:ed:49 from br0
19:18:10 02 Jan. NTP synchronization start
19:18:10 02 Jan. WAN IPv6 Global unicast prefix / length: 2a00:23c7:961b:c100::/56
19:18:10 02 Jan. WAN IPv6 Global unicast address allocated: 2a00:23c7:961b:c100::1/64
19:18:10 02 Jan. WAN DHCPv6 events: BOUND
19:18:10 02 Jan. 2.4G Client disassociate from 82:21:9c:c6:ed:49  (IP=192.168.1.243) RSSI=0
19:18:10 02 Jan. WAN Sensing Auto sensing Complete
19:18:09 02 Jan. WHW INFO A station (SmartHub2)IF[5G](64:CC:22:05:32:CF):STA(82:21:9C:C6:ED:49)(Legacy Device) join WHW infrastructure
19:18:09 02 Jan. WAN Sensing Auto sensing Running
19:18:09 02 Jan. Success - secondary DNS servers
19:18:09 02 Jan. Success - primary DNS servers
19:18:09 02 Jan. WAN connection WAN2_INTERNET_PTM connected
19:18:09 02 Jan. 2.4G client Mac: 82:21:9C:C6:ED:49 Deauthentications (Reason:Deauthenticated because sending station is leaving (or has left) IBSS or ESS)
19:18:09 02 Jan. Self roaming might be occurring... Deauth original one...
19:18:09 02 Jan. WAN DHCPv6 events: INIT
19:18:09 02 Jan. PPP: IPCP up
19:18:09 02 Jan. PPP IPCP Receive Configuration ACK
19:18:09 02 Jan. PPP IPV6CP Receive Configuration ACK
19:18:09 02 Jan. PPP IPCP Send Configuration Request
19:18:09 02 Jan. PPP IPCP Receive Configuration NAK
19:18:09 02 Jan. PPP IPCP Send Configuration ACK
19:18:09 02 Jan. PPP IPCP Receive Configuration Request
19:18:08 02 Jan. PPP IPV6CP Send Configuration ACK
19:18:08 02 Jan. PPP IPV6CP Receive Configuration Request
19:18:08 02 Jan. PPP IPV6CP Send Configuration Request
19:18:08 02 Jan. PPP IPCP Send Configuration Request
19:18:08 02 Jan. PPP: CHAP authentication succeeded
19:18:08 02 Jan. PPP CHAP Receive success : authentication successful
19:18:08 02 Jan. PPP CHAP Receive Challenge
19:18:08 02 Jan. PPP: LCP up
19:18:08 02 Jan. PPP LCP Receive Configuration ACK
19:18:08 02 Jan. PPP LCP Send Configuration ACK
19:18:08 02 Jan. PPP LCP Receive Configuration Request
19:18:08 02 Jan. PPP LCP Send Configuration Request
19:18:08 02 Jan. PPP: Received PADS
19:18:08 02 Jan. PPP: Sending PADR
19:18:08 02 Jan. PPP: Received PADO
19:18:08 02 Jan. PPP: Sending PADI
19:18:03 02 Jan. PPP: Sending PADI
19:17:58 02 Jan. PPP: Sending PADI
19:17:53 02 Jan. PPP: Sending PADI
19:17:50 02 Jan. DSL Link Up: Down Rate=71651kbps
19:17:48 02 Jan. PPP: Sending PADI
19:17:42 02 Jan. PPP: Starting PPP daemon
19:17:42 02 Jan. WAN Auto-sensing detected port DSL WAN
19:17:28 02 Jan. SIP WAN DOWN
19:17:19 02 Jan. SIP WAN DOWN
19:17:19 02 Jan. TLS 0 Close
19:17:19 02 Jan. WAN Sensing Auto sensing Complete
19:17:19 02 Jan. WAN Sensing Auto sensing Running
19:17:18 02 Jan. WAN Sensing Auto sensing Complete
19:17:18 02 Jan. WAN Sensing Auto sensing Running
19:17:17 02 Jan. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
19:17:16 02 Jan. PPP: Stopped PPP daemon(0
19:17:16 02 Jan. PPP LCP Send Termination Request (User request)
19:17:16 02 Jan. PPP: IPCP down
19:17:16 02 Jan. PPP: LCP down
Message 7 of 21
The Hub is just disconnecting, not rebooting.
Message 8 of 21
Margin is jumping around the place..
Message 9 of 21
High resistance fault?
Message 10 of 21
@Keith_Beddoe Forgive my ignorance, but should I ask BT if that's what it could be?
One other thing worth mentioning, The telegraph pole that feeds my line was replaced in August, with a new ASN for the City Fibre connection. So on the pole, the BT box on onside where my cable connects, and City Fibre ASN on the other side of the pole. They actually replaced the Pole, so guessing reattached the BT box
Then all of a sudden I get these drops from September onwards. Coincidence?
