Message 1 of 3
Broadband set up
After receiving the smart hub, do I still need an engineer visit to change the Virgin Media access point to BT? It's my first switchover i'm pretty clueless lol.
2 REPLIES 2
Message 2 of 3
Re: Broadband set up
yes   virgin access point is not compatible with BT/Openreach  if you are getting fibre to home then there will be new cable and now fibre modem (ONT) where you will connect the SH2
Message 3 of 3
Ok thanks!
