Message 1 of 5
New Flat & Issues w Broadband
Just moved into a new flat 603, my flat neighbor 602 has broadband. Open reach says available to order but BT encounters an error when I check for availability on their website. How to fix this issue, could it be a database issue.
4 REPLIES 4
Message 2 of 5
Re: New Flat & Issues w Broadband
If you get an error using the website then often the best thing to do is pick up the phone and as it would be a new contract call 0800 800 150
*That is a BT sales number - but I would suggest googling the number before you call it - never trust numbers anyone posts!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 3 of 5
@Crimliar
that is the old CS number but still works - the new CS 03301234150
@droberts54
if you phone to place order make sure tell them you have an ONT (your pic) and tell them the serial number as it should be registered to your address
Message 4 of 5
I called and mentioned I have a pon green status symbol and my ONT and they said it's something to do with the address checker api they use. Thy recommendation is to reach out to royal mail but I can find my address on royal mail dont know if this will help..
Message 5 of 5
does the royal mail address match exactly to address you are using for broadband package?
you can also try openreach  https://www.openreach.com/forms/fibre-broadband-availability---customer-form
