Message 1 of 4
Bt fttp
Hi or worked on my pole today is this fttp or the beginning of it thanks the left box with wires
image too big aghh
3 REPLIES 3
Message 2 of 4
Re: Bt fttp
If you are talking about a CBT?...(example image below)
...then yes, these are terminals that provide the properties fed by that pole with FTTP. The finished build time could still be a few months though.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 3 of 4
Re: Bt fttp
That’s it yes thank you
Message 4 of 4
Re: Bt fttp
Although it will likely not have any relevant, I will say anyway that my CBT was installed in August time and it was possible to order FTTP from early October from Sky, TalkTalk and Vodafone, however BT/EE/Plusnet and other served by BT Wholesale it was Feb the following year. The reason for this was either work BT Wholesale needed to do, although OR repeatedly said it was done, or it was just a database thing where the Wholesale system wasnt showing it was live.
