Message 1 of 3
CWMP: Initializing transaction for event code 2 PERIODIC
Why does my Smart Hub 2 perform subject transaction every hour?
FTTX, full fibre
firmware v0.42.00.10167-BT updated March 24.
2 REPLIES 2
Message 2 of 3
Re: CWMP: Initializing transaction for event code 2 PERIODIC
As Far as I know, it means that your hub is having problems communicating with the update server
Message 3 of 3
My SH2 log shows the same thing, I believe it's a periodic check with the configuration server to see if there are new updates available.  It should be followed (timewise, so above that message in the Event Log) by a number of other messages, terminating with
CWMP: session completed successfully
CWMP: HDM socket closed successfully.
In my logs these are always about 5 seconds after the 'Initializing' message.
