Message 1 of 15
Cab BT connect to existing open reach fibre cable ?
Hello guys
We cant talk to open reach and my exisiting ISP is Virgin who dont either > want to switch
To be clear My router needs to be in a location other than where cable enters the house ( connects to ethernet patch panel )
While open reach were in my area kindly engineer gave me a suitable length of their fibre cable . I ran it under the floorboards in my house to future proof . LOL  that time is now
QUESTION Will BT /openreach be happy to join to this completely  unterminated cable on the day of switching
( from  cable they run in from the road)  And of course terminate the other end
It is easily accessible at either end and lots of it.
Cable ID
"Dexgreen inside/out IFO G657B3 LSZH   outer CPR B2ca (s1a d0 a1)  UV"
cant send photo too big size But picture y'self A.N.Other ISP cable entering house ( mine is currently coax ( virgin)  Now that cable joins to another under floorboard  coax cable to router in other place Alongside in the house is the black  fibre cable unused and waiting.
Can anyone say if joining to this cable will be a problem for installers. Dont want to dig up the floor boards.  Wish to all go smoothly on changeover day
Understand this is a open reach priority area if that helps
thanks
14 REPLIES 14
Message 2 of 15
Re: Cab BT connect to existing open reach fibre cable ?
Generally Openreach will not use anything you supply because they then have to take responsibility for its maintenance…..some people have success by providing their own cable containment ( duct for example) with a draw cord , the ‘duct’ running from where the customer suspects  the external cable will appear at their property, to where they want the ONT located , the engineer then simply uses the draw cord to pull the Openreach ‘internal’ cable into place …it’s not guaranteed, and obviously this duct or whatever needs to be usable, no tight bends etc .
As far as your router location , you can always run your own Ethernet cable to anywhere you like from the ONT , the ONT position needs the Openreach installers agreement , the other end of your own Ethernet cable is your choice , it’s only if you want the ONT in a specific location and that would require an unreasonable amount of work to get the cable to that location  you need to do some mitigation work yourself….but as stated no guarantee, you may do lots of preparation and the installer still says ‘No , it’s not suitable’ .
Message 3 of 15
Hello iniltius   ( Royal Navy ?)
thank you for that . Ok its luck of the day at best probably unlikely without floor board up. Seems dog in the manger but hey
Could you just advise Is it actually  possible for them join this kind of fibre cable ?   I had it they do this all the time ? dont they have to terminate one end anyway after pulled into the house ?
help with option Ethernet connection  if you would  :  Would that terminate in the router ethernet port ?  Then out to my patch panel ? The other end goes where  Whats the geography
forgive not tech savvy with this.
perhaps I'll just stay with Virgin But sitting duck for their charges.
thanks again for you reply   Ms O
Message 4 of 15
External fibre > CSP ( customer splice point) > internal fibre > ONT  (optical modem) > router WAN (port 4 on BT Smart Hub2) how it gets from ONT to router is immaterial.
Message 5 of 15
Openreach usually want to put the customer splice point on an external wall, as near as possible to the internal wall location of the ONT. So they are unlikely to want to use a length of optical cable that is running under floorboards.
But, as has been commented, it's no problem, just connect the ONT to your hub/router with as long a length of ethernet cable as you need.
Message 6 of 15
Hello Liquorice
thank you/ again  forgive  dummy:  whats an ONT ??  googling as fast as I can   but possible misunderstanding
Is it this "ONT  optical box"  would still require a physical ethernet cable to be run to  " other location of house patch panel   ( across the hall under the stairs actually )  which puts me practically back to under floorboards ?
still seems the only practical solution is forget the house patch ethernet just let open reach drill a hole through the wall plonk the router there use wifi ?  Isnt that what they usually do Do assure many of my neighbors are on BT fibre there is no problem with fibre cable coming to the house
thank you again :  trying to keep fingers crossed but still looks like open floorboards or give up
ms\o
Message 7 of 15
thank you
see my reply to your colleague
looks to me its open the floorboards or give up on the house ethernet network ..
stil like a definitive answer to " do open reach installers  routinely join these fibre cables without second thought ? "
Kit is in the van ?
Then thinking if I left a cup of tea and biscuits  with the open reach guy and a small brown envelope  there could be an accidental loint made  to the cable
or stick with virgin .. They happily join their co ax.
Message 8 of 15
As stated in brackets, the ONT is the optical modem to convert the fibre to Ethernet which is then connected to the router. The fibre doesn't go to the router.
The ONT and router don't need to be co-located, they can be up to 100 metres apart connected via Ethernet.
Just use your fibre cable to pull an Ethernet cable through.
Message 9 of 15
sorry again . bear with . so are you saying I dont need a physical ethernet cable from ONT to router Its an optical connection
Is that what some folks do if they want a router somewhere else other than point of entry to house ? Id need support on that
recommend me one ?
Message 10 of 15
No, you are not reading what I am saying. It is the opposite, the connection from ONT to router is Ethernet. Therefore your cable is not required and can be replaced by an Ethernet cable.
