Message 11 of 25
Re: Change EE
I have received nothing. The BT hub does not connect. The PON light is flashing.
I have all my original equipment, hub, disc and useless modem (sim not working).
Message 12 of 25
Re: Change EE
They stopped the modem two weeks ago, when they messed up.
Message 13 of 25
Re: Change EE
It’s trying to connect, but nothing
Message 14 of 25
Re: Change EE
I have a RM tracking no. That does not work, they are supposed to be sending a new hub, modem etc.
Message 15 of 25
Re: Change EE
If the PON light is flashing, nothing will work so wouldn't make any difference if the kit had arrived. Are EE aware the PON light is flashing, if so what are they doing about it?
You have physical connectivity but your service hasn't been activated.
Message 16 of 25
Re: Change EE
No EE are not aware. I don’t know how to tell them. I’ve been using my BT so far.
Message 17 of 25
Re: Change EE
Until you report that, nothing is going to happen.
Message 18 of 25
Re: Change EE
I’ve spoken to EE but they don’t have any information. Luckily I hope to get callback tomorrow morning. Thanks for your help. I’ll let you know how it goes
Message 19 of 25
Re: Change EE
What info did you get from EE when the migration was set up. You should have got something about the order, how you would pay your bills and how to set up your EE id password. Your MyBT should be showing as inactive but you can still access it but it should also show your new EE account number. It should show the order raised for the migration which would also be shown in your EE account.
Message 20 of 25
Re: Change EE
No information from EE .
MyBT account still active. Where would the EE account number be?
I have a callback from BT and EE tomorrow.
I think this is a right mess up
