Message 11 of 11
Re: Constant issues
Well, a third party router may be a better choice. You are not going to be able to get a faster connection at your location.
I am on a 12mb ADSL connection with an upload speed of 1Mb maximum. I occasionally live stream on YouTube, and also can use the Internet at the same time without any noticeable issues.
I use a TP Link W9970 as my router, with a Tenda Nova MW3 wireless mesh to supplement the Wi-Fi coverage.
This router allows me to allocate bandwidth and priority to each device, so that some background upload tasks can run on a lower priority, allowing Internet browsing to continue. That is provided that the uploading is done on a different device.
Large downloads can be also given a background priority, provided they run on a separate device.
From my router.
Basic Status
Device Information
Firmware Version:0.9.1 0.2 v0076.0 Build 170919 Rel.61201n
Hardware Version:TD-W9970 v2 00000000
System Up Time:35 day(s) 01:15:58
DSL
Line Status:Connected
DSL Modulation Type:ADSL_2plus
Annex Type:Annex A
  Upstream Downstream
Current Rate (Kbps) 1135 12087
Max Rate (Kbps) 1204 12000
SNR Margin (dB) 7.6 2.9
Line Attenuation (dB) 20.6 36.5
Errors (Pkts) 0 0
