Message 1 of 4
DLM reset? Just rejoined
Hi All,
I am wondering if anyone can help I have just rejoined from Sky to BT but it appears that my line hasn't reset itself as I was expecting an 6db NM but I am still on 5db so I think I am on a stuck profile?
Product code:Smart Hub 2
Serial number:+091298+2140006931
Firmware version:v0.31.00.10253-BT
Firmware updated:Thu Mar 24 07:32:19 2022
Board version:R01
GUI version:1.74 12_11_2020
DSL uptime:0 days,04 Hours29 Mins28 Secs
Data rate:19.104 Mbps / 65.729 Mbps
Maximum data rate:19.104 Mbps / 66.145 Mbps
Full Fibre (FTTP) Mode:On
Noise margin:6.1 / 5.1
Line attenuation:9.9 / 16.1
Signal attenuation:9.9 / 18.0
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:617.1 MB Uploaded  / 3.1 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-7MCM9J
2.4 GHz wireless channel:Smart (Channel11)
5 GHz wireless network name:BT-7MCM9J
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:C4:E5:32:40:A5:20
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Thank you
Sam
3 REPLIES 3
Message 2 of 4
Re: DLM reset? Just rejoined
your stats look good with actual connection speed just below attainable - nothing stuck there
Message 3 of 4
Why would you want 6dB when you have 5dB?
Message 4 of 4
Because @licquorice I thought I was still on a sky profile because I was surprised to not see it had been to reset to 6db..
beginning to think it’s a crime to ask questions on here.. especially with some of the responses I get.
I’ve accepted the solution..
