Message 1 of 5
Dangling cable
A few weeks ago, the fibre cable came deteched from one of its fittings and is now touching the top of a tree in the garden of one of our neighbours. I reported this to BT on 27 February and they sent this reply:
Hello,
I have reported a damage/fault on your behalf, one of our engineer will be there in the next 48 hours to make the area safe. Reference number for the damage raised -AF-TPD-2661346964.
Thanks,
BT
Nothing happened so I went on their help chatline but they just kept asking me more and more questions and after half an hour I had to leave for a meeting. How can I get this fixed?
Rob
4 REPLIES 4
Message 2 of 5
Dangling cable
Tried to post this before but can't see the message.
On 27 February, I noticed the fibre cable had deteched from a fitting and was touching the top of a tree in the garden of one of my neighbours. I reported this to BT and got the following reply:
Hello,
Thanks,
BT
Nothing happened so i contacted BT again, but they just kept asking me more and more questions and after half an hour I had to leave for a meeting.
Rob
Message 3 of 5
Re: Dangling cable
Contact Openreach directly and report the problem.
https://www.openreach.com/help-and-support/damage-health-and-safety
Message 4 of 5
Re: Dangling cable
I'm going to be in meetings all next week. Is there a way to report it via email?
Message 5 of 5
Re: Dangling cable
This is a BT customer to customer forum and has nothing to do with Openreach so I am unable to say if Openreach can be contacted by email regarding your problem but I suspect that as no email address is given on their web site the answer is no, you will need to call them on the number supplied in the link I posted or use the chat function at the right hand side at foot of the web page.
