Message 1 of 3
Bt app
My issue is that I have received an email saying my bt hub is up and running but when I try to verify my email to gain access to my BT account is keeps saying to wait 10 mins after receiving my activation email. I received my activation email hours ago and my hub now will not connect to the internet and I can’t use my account to check why.
2 REPLIES 2
Message 2 of 3
Re: Bt app
Morning @Levimcm
Thanks for coming to the BT Community.
Since you posted, have you been able to access your BT account and check the connection status?
If this is still happening, have you tried restarting the router and trying to access your BT account again?
Speak soon.
Leanne.
Message 3 of 3
Re: Bt app
Hi @Levimcm
Have you tried accessing your account via the internet rather than via the app? If so, and it is successful, then you can add it as a shortcut to your Homescreen.
(Company) Apps are notorious for not working as they should and so I find saving a shortcut to a website works better.
I hope you get it sorted x
