Message 1 of 3
Ethernet Connection Keeps disconnecting randomly
Good evening
My ethernet connection drops randomly at times, before posting i have already checked forums and people have had success by buying a TP-Link Router which i have the LS1005G router as suggestged in multiple posts and im still having issues where the connection drops randomly on my pc but the wifi is fine normally and sometimes it is the Wifi dropping for a few seconds
I will post some logs from my router below
2.4G Client associate from f6:38:bc:1d:de:32 (IP=192.168.1.239) RSSI=-73, Rate=72Mbps, host Watch
23:11:44, 19 Jan.
Receive a DHCP request
23:11:33, 19 Jan.
2.4G Client associate from f6:38:bc:1d:de:32 (IP=192.168.1.239) RSSI=-67, Rate=72Mbps, host Watch
23:11:33, 19 Jan.
23:10:49, 19 Jan.
23:10:48, 19 Jan.
23:08:03, 19 Jan.
2.4G Client associate from f6:38:bc:1d:de:32 (IP=192.168.1.239) RSSI=-71, Rate=72Mbps, host Watch
23:08:03, 19 Jan.
23:07:51, 19 Jan.
2.4G Client associate from f6:38:bc:1d:de:32 (IP=192.168.1.239) RSSI=-74, Rate=72Mbps, host Watch
23:07:51, 19 Jan.
23:07:14, 19 Jan.
2.4G Client associate from f6:38:bc:1d:de:32 (IP=192.168.1.239) RSSI=-76, Rate=72Mbps, host Watch
23:07:14, 19 Jan.
23:07:06, 19 Jan.
23:07:05, 19 Jan.
23:06:16, 19 Jan.
2.4G Client associate from f6:38:bc:1d:de:32 (IP=192.168.1.239) RSSI=-72, Rate=72Mbps, host Watch
23:06:16, 19 Jan.
23:02:39, 19 Jan.
2.4G Client associate from f6:38:bc:1d:de:32 (IP=192.168.1.239) RSSI=-72, Rate=65Mbps, host Watch
23:02:38, 19 Jan.
23:01:07, 19 Jan.
Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
23:01:06, 19 Jan.
23:01:06, 19 Jan.
2.4G Client associate from f6:38:bc:1d:de:32 (IP=192.168.1.239) RSSI=-73, Rate=65Mbps, host Watch
23:01:06, 19 Jan.
23:01:04, 19 Jan.
2.4G Client associate from f6:38:bc:1d:de:32 (IP=192.168.1.239) RSSI=-75, Rate=65Mbps, host
23:01:04, 19 Jan.
23:01:04, 19 Jan.
23:00:50, 19 Jan.
ARP [add] br0(wl1) 192.168.1.239 f6:38:bc:1d:de:32
23:00:45, 19 Jan.
DHCP device Connected: 192.168.1.239, f6:38:bc:1d:de:32, Watch
23:00:45, 19 Jan.
2.4G Client associate from f6:38:bc:1d:de:32 (IP=192.168.1.239) RSSI=-75, Rate=65Mbps, host Watch
23:00:45, 19 Jan.
LAN [ADD] ARP 192.168.1.239 with f6:38:bc:1d:de:32 from br0(wl1)
23:00:45, 19 Jan.
23:00:45, 19 Jan.
23:00:45, 19 Jan.
WHW INFO A station (Smart Hub 2)IF[2.4G](A8:A2:37:8C:F8:BC):STA(F6:38:BC:1D:DE:32)(Legacy Device) join WHW infrastructure
22:44:45, 19 Jan.
admin login success from 192.168.1.122
22:44:29, 19 Jan.
admin timeout from 192.168.1.122
22:43:58, 19 Jan.
ARP [del] br0 192.168.1.103 10:91:d1:58:f4:1c
22:43:44, 19 Jan.
DHCP device Disconnected: 192.168.1.103, 10:91:d1:58:f4:1c, Richies
22:43:44, 19 Jan.
LAN [DEL] ARP 192.168.1.103 with 10:91:d1:58:f4:1c from br0
22:43:43, 19 Jan.
5G Client disassociate from 10:91:d1:58:f4:1c (IP=192.168.1.103) RSSI=0, Rate=0Mbps
22:43:43, 19 Jan.
WHW INFO A station STA(10:91:D1:58:F4:1C) leave WHW infrastructure
22:43:43, 19 Jan.
5G client Mac: 10:91:D1:58:F4:1C Deauthentications (Reason:Unspecified)
22:42:28, 19 Jan.
22:42:27, 19 Jan.
22:42:27, 19 Jan.
22:42:27, 19 Jan.
ARP [add] br0(eth0) 192.168.1.122 e8:9c:25:df:84:72
22:42:27, 19 Jan.
22:42:25, 19 Jan.
ARP [del] br0 192.168.1.122 e8:9c:25:df:84:72
22:41:57, 19 Jan.
22:41:57, 19 Jan.
22:41:57, 19 Jan.
22:41:57, 19 Jan.
22:41:43, 19 Jan.
22:41:43, 19 Jan.
5G Client associate from 10:91:d1:58:f4:1c (IP=192.168.1.103) RSSI=-75, Rate=468Mbps, host
22:41:42, 19 Jan.
22:41:42, 19 Jan.
22:41:42, 19 Jan.
22:41:33, 19 Jan.
22:41:33, 19 Jan.
22:41:30, 19 Jan.
DHCP device Connected: 192.168.1.103, 10:91:d1:58:f4:1c, Richies
22:41:30, 19 Jan.
DHCP lease issued 192.168.1.103 to 10:91:d1:58:f4:1c Richies, lease duration is 86400 seconds
22:41:30, 19 Jan.
5G Client associate from 10:91:d1:58:f4:1c (IP=192.168.1.103) RSSI=-74, Rate=585Mbps, host Richies
22:41:30, 19 Jan.
LAN [ADD] ARP 192.168.1.103 with 10:91:d1:58:f4:1c from br0(wl0)
22:41:29, 19 Jan.
22:41:29, 19 Jan.
22:41:29, 19 Jan.
WHW INFO A station (Smart Hub 2)IF[5G](A8:A2:37:8C:F8:BB):STA(10:91:D1:58:F4:1C)(Legacy Device) join WHW infrastructure
22:21:08, 19 Jan.
5G Client associate from 8a:8b:fc:ae:3a:5d (IP=192.168.1.173) RSSI=-50, Rate=866Mbps, host iPad
22:21:07, 19 Jan.
WHW INFO A station (Smart Hub 2)IF[5G](A8:A2:37:8C:F8:BB):STA(8A:8B:FC:AE:3A:5D)(Legacy Device) join WHW infrastructure
22:21:07, 19 Jan.
22:21:07, 19 Jan.
WHW INFO A station STA(8A:8B:FC:AE:3A:5D) leave WHW infrastructure
21:46:17, 19 Jan.
NTP synchronization success
21:46:17, 19 Jan.
NTP Server: ntp.homehub.btopenworld.com
is this an internet issue with it dropping or is it something in need an engineer to see to?
Kind Regards
Richard
2 REPLIES 2
Message 2 of 3
Re: Ethernet Connection Keeps disconnecting randomly
When you say “ethernet” disconnects do you actually mean ethernet, (i.e. a wired connection between the router and the PC)?  Or do you mean wireless (Wi-Fi)?
At a glance, the log is just routine entries.  Nothing jumps out as unusual.  Is there something in that, rather lengthy, extract that particularly concerns you?
If it is an ethernet connection, try a different cable.  Surprisingly enough, cables do develop faults.
If it’s Wi-Fi dropping out, it suggests an interference issue, so try a different channel.  36 is usually particularly crowded so try 40, 44 or 48.
It may be that the signal may not be quite strong enough to reach that far.  In which case you may need to reposition the router.  Putting it up higher often helps, as helps it clear objects.
Edit:  Taking a better look at your log, there are a few reconnects on 2.4GHz there, so I take it is a wireless issue not an ethernet one.  You could try a different channel there too.  Stick to 1, 6 or 11.  The ones between those break CSMA/CA and tend to cause more problems than they solve.  At mid 70's, the RSSI signal strength there is borderline as well.  You really need 60's, so it may be a repositioning of the router problem, as I said before.
Message 3 of 3
It is definitely ethernet cable into my pc, it has being disconnecting and reconnecting non-stop for the last 30 mins to an hour, and often has been doing most nights for the last month, i tried buying the TP link router as the forums on here said that solved there issue but i am still having the issue and it is very frustrating
Majority of the time wifi isnt affected as my tv never disconnects and other devices dont disconnect it is just from the wifi
I will try getting a new ethernet cable and see if that helps
ive attached some more logs from the hub
Screenshot 2026-01-21 233659.pngScreenshot 2026-01-21 233717.pngScreenshot 2026-01-21 233734.pngScreenshot 2026-01-21 233741.png
