Message 1 of 5
FTTC speed dropped by 20-25 mb in the last week
Good morning
I just returned from holiday to find that my broadband is running slower than usual.
Normally, I get download speeds of 75-70 and upload speeds of 18-20. However, now I'm only getting around 50 for download and 18 for upload.
Product code:Hub
Serial number:+091298+2024040737
Firmware version:v0.39.01.04077-BT
Firmware updated:Tue Jun 20 13:06:17 2023
Board version:R01
GUI version:1.77 20_05_2022
DSL uptime:0 days,00 Hours04 Mins27 Secs
Data rate:20 Mbps / 54.999 Mbps
Maximum data rate:25.052 Mbps / 75.104 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:8.6 / 11.3
Line attenuation:7.6 / 15.9
Signal attenuation:7.6 / 16.1
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:19.6 MB Uploaded / 370.4 MB Downloaded
Broadband username:[email protected]
Public Wi-fi status:Activated
2.4 GHz wireless network name:BT-M8AJ3W
2.4 GHz wireless channel:Smart (Channel 11)
5 GHz wireless network name:BT-M8AJ3W
5 GHz wireless channel:Smart (Channel 36)
Wireless security:WPA2
Wireless mode:Mode 1
I don't have a dial tone on my corded phone, so I couldn't perform a silent line test with it. Instead, I used my phone connected to the hub and didn't experience any issues.
Any thoughts?
Thanos in advance
4 REPLIES 4
Message 2 of 5
Re: FTTC speed dropped by 20-25 mb in the last week
was the hub left on when you were on holiday?  connection time is only 4 min was that manual reset?  have you been resetting hoping speed will return?
Message 3 of 5
Hi imjolly
I'm glad to see you're still around, helping the community. You helped me out a couple of years ago.
Yes, it was on while I was away. I performed a manual reset when I noticed the drop in speed.
Message 4 of 5
hope we can help again
by manual reset do you mean just switch off and then on?  i would check the logs and see if the connection has been dropping when you have been away as that would account for speed drop
Message 5 of 5
Yeah mate done a reset via the hub login.
Checked this morning to see if the box was alright and had no issues. Tried to check the line via the master socket so that knocked the net off also.
Will have a good look through the logs.
Cheers
