Message 11 of 13
Re: FTTP 'Not yet available'
Not just swish, as if I go onto bt/ee without logging in then I can order fibre 900 on both sites, the issues start when I log in 🙂
Message 12 of 13
Thanks, think possibly I’m going to experience the same issue, so I’ll check who else I can order through might be easier
Message 13 of 13
As I said, I had the same issue with BT. Login couldn’t order online signed out it’s available. It’s because you’re on GFast. The BT system just doesn't like it. Even when BT CS did orders they all failed (4 times) I eventually had to get a new account to bypass the upgrade.
