Message 1 of 3
FTTP and third party router
Ordered fttp in November. Still waiting for an installation date. So I thought I’d had enough. And I plumped for virgin
ive had so many issues with the bt fttp installation, but virgin is so bad, I’ve ordered bt again. I’ve only had virgin 3 days and I’ve cancelled
however. I bought a ASUS router for the virgin hub 3
can I simply plug this router into the bt ont instead of using the bt hub once I’m up and running?
thx folks
2 REPLIES 2
Message 2 of 3
Re: FTTP and third party router
3rd party router should be ok just use username [email protected] and password of BT. If needed.
With FTTP you will get digital voice if you select phone connection and that will only worK using BT SH2 and not Asus
Message 3 of 3
Thank you. Hopefully the install will go ahead. Been waiting since November but they keep saying blocked ducts
