Message 11 of 11
Re: FTTP installation – Will Openreach install a new duct?
Hi all,
FTTP has finally become available at my address, so I’m now looking at ordering an Openreach-based FTTP service, most likely BT.
This is the reading from the checker:
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG congested duct.
FTTP is available and a new ONT may be ordered.
The exchange is not in a current fibre priority programme
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.
Thank you for your interest
I’m hoping someone can clarify how the installation would work in my particular situation.
At the moment, my BT/Openreach phone line is served via an underground cable. There’s a BT/Openreach manhole in the footpath directly outside my front garden wall. The existing phone line comes from that manhole, passes underground through the front garden wall, and then emerges just inside the garden, marked by the green star on the sketch.
From the BT/Openreach manhole to the green star, the cable is contained within a short length of hose pipe/conduit (it could actually be an existing Duct 100, but I’m not certain). From the green star onwards, the copper phone cable runs exposed along the ground beside the boundary wall separating my property from my neighbour’s until it reaches the front wall of the house, where it enters the property.
My question is about the FTTP installation.
The existing hose pipe/conduit (possibly Duct 100) is only large enough for the current copper phone cable and doesn’t appear to be wide enough to accommodate a fibre cable.
If I order FTTP, would Openreach normally install a new Duct 56 from the BT/Openreach manhole all the way to the house wall, running underground beneath the front garden? Or would they be more likely to reuse the existing route in some other way?
I’ve attached a quick sketch to show the layout. Excuse the messy drawing, but hopefully it gives you an idea of the current setup.
Thanks in advance for any advice!
I think the initial survey will be important in this case, especially because the existing duct is narrow and also serves the neighbouring property. If the current route cannot accommodate the fibre cable, hopefully Openreach can provide a suitable alternative rather than delaying the installation several times. It would be useful to know whether they normally confirm the need for a new duct before the installation date.
