Message 1 of 2
FTTP reboot question
I have recently had FTTP installed and it has been up flawlessly for 14 days and 2 ish hours and then i checked recently and it did a restart and is currently at 0 days and like 1 hour. I have read that this is a firmware cycler that checked for updated firmware every 14 days, If it's not that should i be worried or is it perfectly fine?
Thanks.
1 REPLY 1
Message 2 of 2
Re: FTTP reboot question
I wouldn't worry about it. You wouldn't even know if you hadn't checked.
