Message 1 of 38
FULL FIBRE
I don't want BT Full Fibre but I am being  forced to take it if I stay with BT.  Before the engineer starts digging up my drive and lifting my carpets to lay a wire, will the engineer have some sort of meter which he/she can use to determine that the signal will reach all areas of my fairly large house?
Many thanks, good people.
37 REPLIES 37
Anonymous
Not applicable
Message 2 of 38
Re: FULL FIBRE
While it's not compulsory to get FTTP it's going to become increasingly harder to avoid it
The aim is to get all households on full fibre in the next few years with FTTC being basically switched off.
Best bite the bullet and accept the inevitable
Message 3 of 38
Re: FULL FIBRE
how does  your existing line entre your home - from pole or underground?  there will certainly be no lifting of carpets
Message 4 of 38
Re: FULL FIBRE
If your current broadband is delivered from overhead wires or an existing underground duct, they won’t need to dig up anything.  They’ll more than likely reuse the existing route.  (It's cheaper).  For example, they’ll just push a new cable through the duct.  If it is blocked or it is a wire buried Directly In the Ground, (known as DIG), then they may need to dig.  If it is overhead that can also be done with fibre.
They will not lift carpets.  All they will do is come through the wall and mount a new box on the wall, (called an ONT or Optical Network Terminal).  This will require power and so needs to be within reach of a power point or an extension lead.  It does not necessarily need to be where the old master phone socket is.  The installer will discuss this with you, but he must regard it as do-able in the time allocated, (and be safe to do, of course).
The router then connects to that box instead of the old phone socket.  Anything beyond that point, internal wiring, extensions etc., is your responsibility, (including any Wi-Fi setup), just as it is now.
Message 5 of 38
Re: FULL FIBRE
The signal in your house won't change because of a move to fibre unless you drastically change where your router is located.
Message 6 of 38
FULL FIBRE
Thank you very much, Kodikid.  Good advice albeit painful.  BT have made it clear I must convert to Full Fibre later this year.
Message 7 of 38
RFULL FIBRE
Hi imjolly.  It currently enters underground but I think it highly unlikely that this will be an option this time but there is a pole nearby.  If a wire ran from the pole to the gutter on my bungalow would this be high enough for BT?
The signal will have to reach 22 metres inside to cover all rooms.  Is this realistic?
Does BT have a meter which would test each room for a signal before starting any work?
Thank you!  Greatly appreciated.
Message 8 of 38
Re: RFULL FIBRE
As already stated, unless you change the position of your current router, nothing changes from what you have already.
No
Message 9 of 38
FULL FIBRE
Hi WSH  Many thanks.  Will BT have a meter to test for a signal in each room before starting any work?
Is the signal likely to reach 22 metres.?
Message 10 of 38
Re: RFULL FIBRE
