Message 1 of 23
BT Hub rebooting itself roughly every 3 days (log shows “System start Button press (PowerButton)”)
Hi everyone,
I’ve noticed that my BT Hub appears to be rebooting itself roughly every three days, and I’m trying to understand why.
For example, on 4 March at around 22:33, the router restarted and the system log shows the following entries:
22:33:56 – System start Button press (PowerButton)
22:33:56 – Booting firmware v0.46.02.42261-BT
22:33:56 – System up
Immediately afterwards, all devices on my network reconnect and request DHCP leases again, which causes brief interruptions to services on my network.
This is not a one-off event. I have observed similar reboots before 27 February, and then again on 27 February, 1 March, and 4 March, so it seems to be happening roughly every three days.
The router is connected to a stable power source and no one is pressing the power button, so the log message is a bit confusing. I’m wondering whether this could be caused by a firmware issue, an automatic maintenance reboot, a watchdog restart, or possibly a hardware fault.
The current firmware version is v0.46.02.42261-BT.
Has anyone seen similar behaviour with their BT Hub, or knows whether these routers perform periodic automatic restarts?
Thanks in advance for any advice.
Harry
22 REPLIES 22
Message 2 of 23
Re: BT Hub rebooting itself roughly every 3 days (log shows “System start Button press (PowerButton)
It may be having a problem trying to install an update. Try a factory reset of your BT hub by pressing the recessed button on the rear for about 30 seconds.
Message 3 of 23
Hi,
Been having the same issues seems to be restarting every 3 days, just done a factory reset, to see if make a difference.
Message 4 of 23
Hi Again,
Ours still doing it , restart at 2:10am in morning:
02:10:44, 14 Mar.
Booting firmware v0.46.02.42261-BT (Fri Dec 26 15:42:12 2025)
02:10:44, 14 Mar.
Message 5 of 23
Hi Everyone,
Still doing it after the factory reset of the hub, what best thing can do get this sorted, is bug with this firmware causing it?
09:23:02 16 Mar. admin login success from 192.168.1.157
04:36:52 16 Mar. Booting firmware v0.46.02.42261-BT (Fri Dec 26 15:42:12 2025)
04:36:52 16 Mar. System start Button press (PowerButton)
02:10:47 14 Mar. Booting firmware v0.46.02.42261-BT (Fri Dec 26 15:42:12 2025)
02:10:47 14 Mar. System start Button press (PowerButton)
09:49:22 12 Mar. Booting firmware v0.46.02.42261-BT (Fri Dec 26 15:42:12 2025)
09:49:18 12 Mar. System start Button press (ResetButton)
Message 6 of 23
Hi, I am still experiencing the issue after the reset. The firmware version also did not change after the factory reset.
Message 7 of 23
Might be a failing power supply unit, but if it is exactly every 3 days that would seem to suggest something more sophisticated.
Phone customer services and ask for a replacement router.
Message 8 of 23
Been in a BT Live chat, managed to get replacement router, which is now installed, awaiting to see how this one goes.
Message 9 of 23
I don’t understand why a response was marked as a solution when it hasn’t resolved the issue raised for at least one person.
Message 10 of 23
Me neither, I didn’t mark it.
