Message 1 of 6
Fast.com
Everyone here seems to recommend fast.com (as do the engineers that come out) but every time I do a test with them I get speeds of about 1.4 Gb which is impossible as:-
1) I only have a 900Mb service
2) The SH2 only has Gb ports
3) The PC only has a Gb NI
Given the above can we believe the results from it?
5 REPLIES 5
Message 2 of 6
Re: Fast.com
I've always found fast.com very sketchy to say the least. I've just tested over 5G and it showed double the speed that Ookla Speed test showed
Message 3 of 6
Re: Fast.com
Hi @JonMace and thanks for posting.
I've used fast.com previously myself and got conflicting results. I would generally use Test your BT Broadband Speed | BT Help on a wired connection for the best results.
Cheers
David
Message 4 of 6
Re: Fast.com
That test no longer works, it tells you to test on the My BT app
Message 5 of 6
Re: Fast.com
Thanks for pointing that out @JonMace , I stand corrected.
I haven't used it in some time I must admit.
Cheers
David
Anonymous
Not applicable
Message 6 of 6
Re: Fast.com
Just use https://www.speedtest.net/
It gives me accurate results, fast.com never has, its always more than my actual speed
