Message 1 of 2
Fibre Cable to run - Flat to Cupboard
People, what is the minimum fibre cable that needs to be run from each flat to the cupboard where BT can then split
This is for independent internet to a block of 5 flats each
Is 2 core fibre enough?
1 REPLY 1
Message 2 of 2
Re: Fibre Cable to run - Flat to Cupboard
@secure1
This is a BT Retail  Customer To Customer Forum.
As its Openreach that provide the external network, you need to look at this site.
https://www.openreach.com/building-developers-and-projects/fibre-for-developers
All the installation guides can be found there, and you can register your project and get advice.
BT Retail has no connection with Openreach, who provide the network for many providers.
