Message 21 of 25
Re: Fibre availability confirmed by Openreach but suppliers say fibre NOT available
Thank you. I did say that my questions would probably be naive, but if you don’t ask…My logic was that the people responsible for the infrastructureMIGHT be interested in a fault or an error on that infrastructure and/or their hardware and a human being on the ground might be able to escalate it or point the query in the right direction. There IS an economic/commercial aspect to this…namely the fact that a part of the same group (EE) are being paid over £100 a month by me for other services, yet don’t consider me sufficiently “a customer” to do anything other than hand me off to  call centres that end up as dead-ends…so your suggestion of a complaint to the corporate bigwigs maybe would be a good idea if all else fails.
I’ll continue to wait for a response from OR to the form, but in the meantime count my blessings…such as getting between 0 and 12 mbps on the EE dongle that costs 60% more than a 100mbps fibre.  I have to laugh, or else I’d cry!
Message 22 of 25
This may ultimately change nothing substantive but on the DSL checker instead of using the address option try the DN/ALID/UPRN option ( the UPRN specifically) there are a few UPRN lookup resources to find it if you don’t already know it (I doubt anyone actually does know their UPRN) , if you try it , does that change the survey information to what I suspect it should show in your case  ,
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG Feed with no anticipated issues.
ONT exists with active service. No spare ports are available. Network is at capacity so a new ONT cannot be ordered.
Unfortunately even if it does show a positive indication that FTTP is available or even an ONT exists (although no active service ) as far as I know no ISP uses UPRN’s (unique property reference numbers ) to raise an order with Openreach
Message 23 of 25
Thank you. I’ve just done the search with the UPRN and it returns “FTTP is not available” , with none of the additional comments you suggested. Don’t know if it’s relevant but it does say the exchange is an FTTP priority exchange, is a WLR withdrawal exchange, and has no SOADSL restrictions .
Message 24 of 25
For interest, I’ve just done the UPRN checker search for the house next door…it returns exactly the wording you expected
Message 25 of 25
It was just idle curiosity to try the UPRN .
Most of the extra notes like WLR withdrawal are pretty standard , FTTP priority exchange means your exchange area has a very high percentage of FTTP availability , so an address  with historic access to both FTTC and FTTP will have no choice but to take FTTP for new service  , but it doesn’t materially affect your individual address , and it’s not as if FTTP was retro fitted into your address after the  copper pair service , so you could somehow try to take a FTTC service as a ‘consolidation prize’ , in your case as a newish build it’s FTTP or nothing , and unless the address data has the error corrected , ISP’s won’t be able to raise an order , as stated previously it’s odd this error appeared after Sky apparently successfully ordered service in the past .
Its just a case of hoping that sooner rather than later OR contact you to say the error has been corrected.
