Message 1 of 3
Fibre connection dropping out
After years of flawless BB connection, I have been experiencing drop outs recently ( 4 or 5 within the last 4 days) with the HH6 showing an orange light. Only way to restore my connection is to reboot the router.
The router is connected to the master socket which is a filtered socket separating BB and phone line. Phone line itself is working and, although a little static, seems quiet enough.
Would this be a router issue as it's now quite old or a line issue? I can't get far enough back in the Event Log to check what it says.
Here's the Router Stats.
Firmware version:
SG4B1000E079
Firmware updated:
19-May-2022
Board version:
1.0
Gui version:
1.126.0
DSL uptime:
0 Days, 11 Hours 50 Minutes 40 Seconds
Data rate:
20.00 Mbps / 80.00 Mbps
Maximum data rate:
28886 / 89094
Noise margin:
15.5 dB / 4.6 dB
Line attenuation:
23.8 dB
Signal attenuation:
17.2 dB / 23.9 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
766 MB Uploaded / 4 GB Downloaded
2 REPLIES 2
Message 2 of 3
Re: Fibre connection dropping out
can you check your phone line - dial 17070 option 2 should be silent and any noise is a problem and could be cause of unstable connection so would need reported as phone fault to 151  best done with corded phone
Message 3 of 3
I've tried the quiet line test and no noise.
