Message 1 of 5
Fibre installed
I'm a bit confused if I have fibre or not have a look at this photo. Screenshot 2024-10-01 200612.png
 I have recently had Openreach down my road they have installed a cbt. Do I have fibre if not how can I get it (Preferably Free)?
4 REPLIES 4
Message 2 of 5
Re: Fibre installed
No, you don't have fibre as it is not available to you. You would know if you had, as you would have had a new fibre cable fitted with an optical modem (ONT) installed instead of your master socket.
Message 3 of 5
Re: Fibre installed
Yes but I mean is it avaliable for me to get an ONT. We have a cbt on out pole but am I able to get an ont yet??
Message 4 of 5
Re: Fibre installed
As stated previously, no.
Just because a CBT has been fitted it doesn't mean the rest of the fibre infrastructure has been completed.
Message 5 of 5
Re: Fibre installed
Keep checking , when the CBT has been commissioned and ready for service, the DSL checker will show WBC FTTP as available, there is lots more to providing FTTP that simply putting a CBT at the top of a pole but with luck it should not take too long for the checker to indicate FTTP as available
