Message 11 of 20
Re: Fibre-optic cable colour?
The cable they use is roughly 5mm in diameter, if you can get some sleeving that'll go over that, then most installers wouldn't have a problem in using that over their cable.  If they do, you can always do it later by splitting the sleeve and then securing it in place in a non-damaging manner.
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 12 of 20
The inner Micron Core Layer isn’t resistant to UV Rays, hence the outer Black Sheathing for the outside.
If you strip it down to the Inner Core and expose that on the outside it’ll soon breakdown and you’ll then have an unsightly broken cable with Kevlar Yarn hanging all over the place, which if a dog or cat decides tastes nice that’ll be a very expensive visit to the Vet to have it detangled from their intestines.
Message 13 of 20
If you get the correct diameter 5mm (and larger) is available, so you don't need (and shouldn't anyway) strip that outer sheath.  Putting the brown sheath over the top of the complete existing cable will not cause any damage.  All I'm suggesting is adding an extra layer, not removing anything!
*You'd need to order the sleeve online, as it's not available from the common DIY stores.
Message 14 of 20
How do you propose the extra sheath by applied?
Is it pushing it on as the installer is running it off the reel and trying to feed it to where he needs the fibre to go or is it after he has fed and clipped it to where it is meant to go?
Either way I doubt the installer will be prepared to agree to the process as it will obviously add time onto his install
Message 15 of 20
You could of course just paint the cable once the installation has been completed. A water based paint is probably best to use and I have done this successfully with co-ax TV aerial cable where I, paradoxically, didn't like the standard brown colour
Message 16 of 20
@chrisjp Any paint that doesn't chemically bond (ie you can peel it off if need be) is good.  I've seen this done to great effect on granite built houses, even with a different colour to blend in with the mortar, and you can hide the clips too!
@gg30340 Sleveeving comes in multiple sizes and types.  Some is semi-rigid, you can split it and clip it over the cable.  Other sleeving can be much thinner, you literally just drop it over the cable, and it's so thin it'll still fit in the existing clips the OR engineers use - its literally a 5 second job to drop it on, as you only need it on the visible part.  It really is that simple an ask, that if an engineer won't do it for you, then you are probably the problem!
Message 17 of 20
Oh, so you meant remove the black sheathing and then replace it with a brown?!?!
Yeah, when I was on Tools if an EU asked me that I’d tell em to knock themselves out and do it themselves long after I’ve gone.
Message 18 of 20
No, just get some sleeving that will go over the top, you can and must/should leave the original sheath in place!
Message 19 of 20
We used to have a saying for that, ‘Over Engineering a Problem that Doesn’t Exist’.
Message 20 of 20
@36ULW trying to help @Leo584 with a request about masking the cable, so it looks neat and tidy.  That cable with the black outer can look out of place if it has to run any distance!  I've done the same with ethernet and cable to satellite dishes when the only option was to run it around the outside of a building with entry and exit points in window frames (not at my own property).
