Message 1 of 5
When fttp comes to my area will I be forced on to it or will I be able to stay on copper wire connection to my property (ie. Stay on fttc)
4 REPLIES 4
Message 2 of 5
Re: Fttp
You can stay on FTTC. You don't have to upgrade currently
Message 3 of 5
Re: Fttp
Thank you. Notice you say “currently”. Do you think we will be forced? If so any guess as to how long?  I ask because of the disruption running fiber to me property would cause
Message 4 of 5
Re: Fttp
Who knows. When you are the last customer connected to the cabinet I doubt Openreach will keep it working just for you.
I can sympathise though, it would be a massive disruption to provide me with fibre and I'm not keen either.
Message 5 of 5
Re: Fttp
