Message 1 of 3
Full Fibre 100
I am considering an upgrade to Full Fibre 100. I need to consider the location of the 3 boxes before I proceed. In particular is the connection between the Fibre Modem and the Smart Hub 2 a standard ethernet connection ... so is there any reason why I cannot use a standard Ethernet Cat6 10 or 15m patch cable to allow me to place the router in the center of my house.
2 REPLIES 2
Message 2 of 3
Re: Full Fibre 100
just standard ethernet cable from ONT to SH2 and no reason why it cannot be 10/15m long
Message 3 of 3
Re: Full Fibre 100
You can use a CAT5e or above patch cable up to 100mts to place your hub wherever you want.
