Message 1 of 5
Full Fibre Installation in my area
Hi ,
Full fibre is currently being installed in my area but my house is a new build and I think we've been missed off the full fibre installation program , there's approx. 33 houses which would be more than likely to switch to BT if we were able to as currently our only option is KCOM.
Postcode : HU15 2GW
4 REPLIES 4
Message 2 of 5
Re: Full Fibre Installation in my area
it would have been up to your developer to arrange with openreach to install fibre connections but maybe restricted being in KCOM area
Message 3 of 5
Hi , the full area has BT installed as well as KCOM but the developer went with KCOM to do the initial install which was over 2 years ago with no more new builds being built and no restrictions for BT to expand there network by a further street , especially whilst they're currently installing the neighbour streets.
Message 4 of 5
Hull area is unlike any else in the country in that KCOM are the incumbent, not Openreach , and presumably if OR were to overbuild they would be effectively an Alt Net , no different to City Fibre , Netomnia….KC have not been subject to the same scrutiny over their PIA as Openreach were , so competition in the Hull area isn’t widespread.
I suspect OR don’t intrude onto KCOM although the same can’t be said for KCOM who do compete in OR area’s, but KCOM are minuscule in comparison.
As stated , if this is a new build site and KC have built the network presumably you are stuck with them , unless an Alt Net comes along , that’s unlikely to be OR in my opinion
Message 5 of 5
only openreach know when or even if they will install fibre in your area  you can try contacting openreach and see what they say  https://www.openreach.com/forms/fibre-broadband-availability---customer-form
