Message 1 of 3
Full Fibre
Hello,
We are in the process of getting full fibre in my area,Port Seton,East Lothian.
According to the online checker provided in the sticky posts, FTTP on demand 330mb is available.
Just using the normal bt checker,FTTP on demand 330mb isn't showing.
What checker is correct,and if FTTP 330mm is available,how do I order it
2 REPLIES 2
Message 2 of 3
Re: Full Fibre
FTTP on Demand is not the same as WBC FTTP.
FTTP on Demand is a business service where you pay £££ to have FTTP installed to your property and has a large monthly cost. BT Consumer do not offer a FTTP on Demand service. They do offer a Full Fibre service over WBC FTTP but it can take time for it to be built out by Openreach so just keep an aye out.
As an example, from seeing CBTs and overhead fibre being deployed it can take in some cases 12 months or more depending on how the build and testing is progressing.
Message 3 of 3
Re: Full Fibre
I see,thanks for clarifying that.
Cheers
