Message 1 of 3
Full fibre broadband PPP resets
I had full-fibre broadband installed a month or so ago and ever since it was installed I see my Smart Hub 2 lights regularly changing from blue to orange and purple.
Looking in the Technical Logs I see that this coincides with PPP resets which are happening several (but sometimes dozens of) times a day. As soon as the PPP drops it renegotiates and comes back in a minute or so.
I'm sure this isn't normal. Any ideas what could be causing this instability?
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: Full fibre broadband PPP resets
have you tried a factory reset by pressing the recessed button on back of hub and holding until the hub lights flash.  if that does not fix it then call CS 03301234150 and report a fault
do the lights on the ONT change colour from green?
Message 3 of 3
@bus-error
If you have Digital Voice make a backup of your settings/contacts before doing a reset.
