Message 1 of 3
Full fibre losing connection
I had full fibre installed about 2 weeks ago and the connection is awful. It's forever going off sometimes for as long as an hour. I've reset the box numerous times but it doesn't make a difference.
Any suggestions pls
2 REPLIES 2
Message 2 of 3
Re: Full fibre losing connection
what colour are the lights on the ONT - small white box?  what colour light is on BT hub?
are you connecting using Wifi and it is your wifi that is dropping not your actual internet connection?
can you connect using ethernet cable and is connection then stable?
Message 3 of 3
Is it the ONT that’s losing a connection?
If so it’s possibly got a High Light Fault.
When I was a CST the threshold was -27dBm at the ONT but ideally it’s wants to be no more than -25dBm.
