Message 1 of 4
Beeping
Lots of high pitched beeps coming from wall box. Is this normal?
3 REPLIES 3
Message 2 of 4
Re: Beeping
What Wall Box, an ONT, NTE, DSL Modem?
Are you sure it’s coming from said wall box and not your Smoke Alarm as the Beep to indicate a Low Battery.
Message 3 of 4
Re: Beeping
Has your ONT got a battery backup unit in it? it's like a UPS but just for the ONT and I think Beeping can indicate a fault with the battery backup unit like dead batteries. Honestly the backup is p useless and openreach don't even support them properly anymore so I'd just bypass it if that's the case.
-Jade
Message 4 of 4
Re: Beeping
The Battery Back Up’s Openreach used to supply don’t Beep to indicate a low or faulty battery. It would just indicate a problem with a, Fault Light.
