Message 1 of 4
Full fibre
Can anyone tell me please the diameter of the full fibre cable that BT use to bring it into the house?  And are there any illustrations and dimensions of the box that they fit inside the house?  Thanks
3 REPLIES 3
Message 3 of 4
Re: Full fibre
Many thanks.  Very helpful.  Do not know why BT did not direct me to that!
Message 4 of 4
Re: Full fibre
A simple Google search would have discovered it.
