Message 21 of 23
Re: Halo 3 (FTTC) extremely slow upload speeds (less than 1mbps)
You could check to see if you were on a split pair by looking at the A and B legs on the rear of the master socket , if it’s not a ‘twisted pair’ as stated this may account for the poor upload performance…if it is a split pair , unless there is a serviceable ‘pair’ in the existing ( presumably 5 pair ) cable , the cable may need repair or replacement, and if it’s a DIG cable ( not ducted ) that could be a significant undertaking, and as upload isn’t guaranteed, you may need to make a case for it to be done .
Message 22 of 23
Thanks, that sounds interesting, but wouldn't explain why it's csbges recently
Message 23 of 23
Thanks, there's a connection twix the ug feed ( it is in duct100) and the internal wiring, you've given me an idea!! I'll check the crimps and probably reterminate the joint. I'll checkbthe pairs at the same time though.
