Message 11 of 16
Re: How long is a reasonable time to be without internet
Then a new hub won't help. Have you spoken to the FTTP team? 0800 587 4787
Message 12 of 16
Thanks for the quick responce. Before i call them can you give me any advice.
Many thanks
Message 13 of 16
Have the serial number of ONT handy. If you get diverted to CS  as FTTP busy then hang up and try later
Message 14 of 16
Have the serial number of ONT handy. If you get diverted to CS  asFTTP busy then hang
Message 15 of 16
Not really, it would appear your service hasn't been provisioned correctly if your Pon light is solid green but no service with FTTP mode enabled on the hub.
At busy times, that number diverts to the normal help desk, try again if it does.
Message 16 of 16
Absolutely brilliant advise. Spoke to the FTTP service desk who confirmed nothing was wrong with my Smart Hub. They are sending an engineer out Friday morning to fix/investigate the issue. BT are sending me a mini hub with unlimited data To get me up and running until fixed
Thanks again
