Message 1 of 6
How often should Halo drop out?
I am going to start keeping a log but it drops, the phone cuts off (have the much-hated digital voice) and the router light has changed from blue to purple/flashing etc. Is this the norm for BT in the evenings or when traffic is higher?
I don't notice it as much as just when using the laptop but with digital voice is causes a lot of confusion for the person at the other end who gets cut off.
I just wondered what others experience. Thanks
5 REPLIES 5
Message 2 of 6
Re: How often should Halo drop out?
@Lila Digital Voice should not cause issues like you are experiencing. It sounds like there's an underlying issue with your broadband connection.
Are you on FTTP or FTTC?
Message 3 of 6
Halo is an only benefits  package , so Halo your halo doesn’t drop out , and obviously if your telephony is IP ( Internet based  ) and the ‘internet’ goes off , so does your telephone.
As stated , are you FTTC ( fibre to the cabinet ) or FTTP ( fibre to the premises ) , if FTTP as well as the router dropping out and reconnecting, does the ONT ( the mains powered box the router connects to ) also showing any errors during this downtime, like the PON light going off or flashing , or the LOS light comes on ?
If FTTC it’s harder to do any fault locating yourself, but if you lose connection frequently, then report it to your provider, that presumably is BT are posting here .
Message 4 of 6
I'm assuming it's fibre to the cabinet.
I'm afraid I have no idea what an ONT is. The router is plugged into the wall - that's all.
The connection has dropped twice already in the last 2 hours. Is it normal for BT to do this, presumably when traffic is higher?
Message 5 of 6
No, it is not normal, you have a fault.
Message 6 of 6
Phone CS 03301234150 and report a fault with connection dropping
