Message 1 of 2
How to chase up a blocked ducting problem on FTTP install.
Openreach just came to install FTTP from the road to our house. Said duct was blocked and that they will have to do a pull through using the current copper cables.
Within a few minutes of him leaving I was sent confirmation of my installation date.
Are these just automaticallygenerated or a sign that he didn't find any show stopper.
Chris
1 REPLY 1
1 View
Message 2 of 2
Re: How to chase up a blocked ducting problem on FTTP install.
A, ‘Pull Through’. Never heard that Terminology before.
Confused as how they plan on doing a, ‘Pull Through’ when the Duct has a Blockage.
Only thing I think they could mean is to use the existing Copper Cable as a Draw Rope for the Fibre.
Bit risky doing that because if they fail to pull the fibre through they might not be able to retract the Copper Cable to reconnect your existing service.
