Message 1 of 6
How to check smart hub 2 firmware and when it updated
Basic newbie question. How do I check the firmware on my smart hub 2 and when it last updated please?
5 REPLIES 5
Message 2 of 6
Re: How to check smart hub 2 firmware and when it updated
enter 192.168.1.254 into address bar then go to advanced settings then technical log information and firmware version and date update shown
Message 3 of 6
An alternative, (without having to enter your admin password):
Enter 192.168.1.254 into browser address bar then click on Status. This will display a summary of status info including firmware version, date updated, and system uptime.
Message 4 of 6
I fail to see why this information would be useful.
You can't roll back a firmware change.
You can't force an update.
Why on earth would you need to know? It would change nothing for you.
Message 5 of 6
Maybe I want to make sure I have been updated with the latest and any bugs can be reported or matched to others on the same firmware.  Not rocket science but thanks for your helpful reply.
Message 6 of 6
I understand what you are saying but there is absolutely nothing you can do to change it so how does it help?
