Message 1 of 5
How to relocate my router? Open Reach?
I'm considering moving my router to a more convenient location in my home.
This is due to having a number of items which require access to my router and its becoming very cluttered.
Who do i contact to move my open reach box and how?
Also would anyone be able to give me approximates  of how much it costs to move the box within the house? I want to move it from the living room to a storage area either at the bottom of my stairs or at the top of the stairs?
Michael
Tags (2)
4 REPLIES 4
Message 2 of 5
Re: How to relocate my router? Open Reach?
are you a BT broadband customer?  do your have FTTP (fibre to your home) or FTTC and connect to standard phone socket?
Message 3 of 5
@MichaelOzz  When you state "Openreach box" I assume you mean the Optical Network Terminal if you are on Fibre to the Premises? Is there a reason why you cannot purchase say a length of flat ethernet cable and run that from the ONT where it is currently sited to where you wish to relocate your router? I assume that it is the router you want to re-site? Self help would quite possibly save you a lot of expense.
I'm assuming that your router is currently sited next to the ONT?
Message 4 of 5
https://www.openreach.co.uk/orpg/home/products/pricing/loadProductPriceDetails.do?data=hcaYjIWegP2u2...
Internal ONT shift £109.67 excluding VAT , this is what Openreach charge the ISP , what the ISP charges you (assuming you can get an order raised in the first place ) will probably be more once they add in their time and trouble to arrange it on your behalf , this charge would appear on your regular ISP bill not billed separately from Openreach, you don’t arrange anything directly with Openreach, you contact your ISP , they arrange it with OR .
As stated this is assuming the box in question is the ONT , and that the new location is suitable,  so it can be safely accessed , isn’t totally impractical etc, there are limits even if you are paying handsomely for the service.
TBH, I think you would be better advised to run your own Ethernet cable from the ONT location to the ‘new’ router location yourself , or employ a tradesperson to do this for you if your DIY skills are not sufficient.
Message 5 of 5
Just to round out the other comments here, theoretically you can have up to 100m of ethernet cable between the ONT and the router.  80-85m is more realistic in practice.  You want Cat 5e or Cat 6.  Anything higher is a waste of money.  Avoid anything labelled CCA (Copper Clad Aluminium).  It’s rubbish.  You want pure copper.  Flat cable also varies a lot in quality.  Round cable is better.
