Message 1 of 13
Hub disconnects
Our HomeHub 2 has been dropping connection quite a lot these last few days. I forced a restart from MyBT which seemed to work until we encountered another restart.
I wonder if any of you experts can see anything untoward in the event log?
Screenshot 2023-12-21 122821.pngScreenshot 2023-12-21 122802.pngScreenshot 2023-12-21 122745.png
12 REPLIES 12
Message 2 of 13
Re: Hub disconnects
Hello,
multiple reasons why to external fault to an internal bridge tap fault, also could be over subscribing so in peak times it drops out.
anything at home changed from your package to the devices using it?
When the router drops this a network drop which will be displayed by an orange light if it is then this would need to be investigated.
also is the speed consistent all throughout the day?
Hopefully some of this helped in anyway?
Hope this helps! 🙂 If you like my reply and
want to say thanks for the helpful answer
then please click on the Kudos on left hand
side 😉 also if I answers your question correctly please let us know by clicking on Mark as Accepted Solution 😄
Message 3 of 13
Re: Hub disconnects
Thanks for the reply. The last disconnect was last night at 10:13pm and was back around 10:15pm. I was surprised to see how large the event log  was around these few minutes. Unfortunately, this portion of the log means little to me and would appreciate any advice if anyone can see a specific reason.
Message 4 of 13
Re: Hub disconnects
It just indicates a loss of incoming broadband signal. It could be a bad connection, or a lot of electrical interference. Older gas boilers tend to cause a lot of interference if the boiler thermostat is worn out. This normally causes interference about every 20 seconds.
It may be worth checking the connections on your master socket, especially if its a 5c type.
Message 5 of 13
Re: Hub disconnects
Thanks @Keith_Beddoe
Connection dropped yet again just minutes ago. This was again accompanied by a frenzy of activity in the Event Log.  Plugs checked again - all seem OK.
We're located in a block of flats, 66 apartments, all on FTTC but with a huge assortment of ISPs. I'll ask on the building forum whether anyone has had any disconnects.
Message 6 of 13
Re: Hub disconnects
Is your master socket located in the apartment?
Normally there will be an internal DP (Distribution Point) somewhere within the building complex which should normally be locked, but Openreach can normally get access from whoever owns the building.
From that DP, there would be a cable to each apartment, terminating in a master socket.
What does your master phone socket look like?
Message 7 of 13
Re: Hub disconnects
@Keith_Beddoe Thanks for the reply.
No other residents have reported any real problems bar one lady who posted on our B Group. "At flat 42 we have had some intermittent problems" without elaborating as to what these might be.
Our master phone socket is a 5C that replaced the previous socket some 3 years ago.
Connections have been stable so far today.
I shall continue monitoring.
Seasons Greetings to all that read this thread!
Message 8 of 13
Re: Hub disconnects
@Carlusha
That master socket is known to give problems, and maybe the cause of the disconnections.
You need to connect things up as shown below, and see if you still get disconnections. Leave it like that for a few days.
NTE 5C Test socket check
Message 9 of 13
Re: Hub disconnects
Cheers @Keith_Beddoe
I will try this for sure. It will have to be late this evening when the Boss is sleeping as she is forever watching streams from her Ukraine!
Message 10 of 13
Re: Hub disconnects
The issue with the 5C is caused by poor contact between the front and back sections. Even the slightest bit of vibration caused by people walking past the socket, can cause the connection to fail. The two parts are only held together by clips, unlike earlier sockets that were screwed together.
Any slight mis-alignment can mean there is nothing to guarantee a good contact.
By using the test socket, it eliminates one possible cause of disconnects.
