Message 1 of 5
IPv6 via Hybrid Connect
I'm in the process of switching from FTTC to FTTP, and have received my new Smart Hub and Hybrid Connect. I have set these up, and, even though I don't yet have the fibre connection, I can get an IPv4 connection via the Hybrid Connect. However, I can't get an IPv6 connection.
Is this to be expected?
If not, what else do I have to do?
If this is to be expected, will I be able to get an IPv6 connection when I get properly connected?
4 REPLIES 4
Message 2 of 5
Re: IPv6 via Hybrid Connect
IP v6 will be available on FTTP but not on Hybrid connect.
Message 3 of 5
Thank you. That explains it. I'll have to have a think about the implications, now.
Message 4 of 5
There are very few sites that are IPv6 only.
Message 5 of 5
Yes - I know, but I have my own sites on my own servers at home, so I was thinking about offering IPv6, rather than using it to access other sites.
Anyway, I'm happy with the answer,  thanks.
