Message 1 of 23
If I switch from BT to EE do I get the new Wifi 7 router off EE
Currently out of contract with BT
22 REPLIES 22
Anonymous
Not applicable
Message 2 of 23
Re: If I switch from BT to EE do I get the new Wifi 7 router off EE
It depends..if you order the 1.6 or 900mbps package yes .
Anything less then you can still get it but it's £10 a month.
Alternatively buy one from Ebay.
Message 3 of 23
Thanks, is it a smooth switchover? Just saw on the choose your package section the Router is listed as a £10 monthly extra. Is that to all new customers or just switchers from BT.
Anonymous
Not applicable
Message 4 of 23
It should be straightforward but you can never tell.
Apparently the wifi 7 router is only now "free" with 1.6 mbps. Everyone else including new customers it's £10 monthly.
If you're switching to EE you are entitled to the wifi 6 router which you will find is a vast important over your current BT router.
Message 5 of 23
Thanks, is the wifi 6 router sent or is it one you have to beg for. Might be worth switching just for the better router and can get a 12 month contract cheaper for some reason, annoyingly the prices seem to change every time I log into either BT or EE to check options to switch 🙂
Anonymous
Not applicable
Message 6 of 23
You have to ask otherwise they expect you to keep the BT router.
Message 7 of 23
Thanks for all your help
Message 8 of 23
If you google "EE WiFi7 router", you'll see several options to buy this item, which might work out cheaper in the long run than paying a monthly rental charge
Anonymous
Not applicable
Message 9 of 23
Lots on ebay for around £60. Not bothered personally as it's white and too high for where my router lives and not completely convinced it's a vast improvement over 6.
Message 10 of 23
Do you know if the EE router will work with BT broadband
