Anonymous
Not applicable
Message 11 of 23
Re: If I switch from BT to EE do I get the new Wifi 7 router off EE
BT EE and Plusnet are all the same
Message 12 of 23
So it'd work out of the box with BT as with the Smart Hub 2 the username password seem to be hard coded and no way i can change them, I'd assume it'd be the same with any EE router too.
Basically out of contract and no cost difference between BT and EE but reading the forum seems setting yourself up for a fall switching to EE. Could go to Sky but they just give out a Wifi 5 router on the 500mb package which is all i need in terms of speed. Main stumbling block is having a landline as don't want the hassle of getting new phones when i have the DV ones already
Message 13 of 23
The SSiD and password can be changed on the Smarthub 2. I've done it on many SH2s.
Message 14 of 23
How? They're just greyed out when I access them via the web interface
Anonymous
Not applicable
Message 15 of 23
I too have BT 500mbps..with the BT router  I was averaging 200mbps
Bought EE wifi 6 router for £30 plugged it in and now it often exceeds the 500mbps
Message 16 of 23
Thanks that was the sort of thing I was possibly aiming to do as quite happy with BT but with kids and lots of WiFi hungry connections thought W6 might be a good idea. Did you have to tweak the EE router at all?
Message 17 of 23
Log on to the hub management page the click on the wireless section. In the lower menu bar click on "Change Settings" then enter your admin password which then opens the "Advance" settings. You should now be able to click on the SSiD and Password boxes and make any changes. Remember to click save when you finished.
Anonymous
Not applicable
Message 18 of 23
No it really is plug and play
Message 19 of 23
I was talking about the login to the network which is set as [email protected] rather than the wifi network details, thanks
Message 20 of 23
So [email protected] would work with EE and whatever is set on the EE router work with BT?
