Message 1 of 3
Installation Engineer Visit - status provisional
I changed the proposed date of my lnstallation Engineer Visit to tomorrow 4th December. It has been showing as a provisional only date in the status for over a week now. Anything I can do to get confirmation. I have taken the day off work - not just for this I should add, but it'll be a real pain if it doesn't happen.
2 REPLIES 2
Message 2 of 3
Re: Installation Engineer Visit - status provisional
Hi @BJ2023, sorry you didn't get confirmation of the appointment change.
It sounds like the change hasn't gone ahead so I would suggest you call in to check. It may need a new appointment booked. I'll send you a Private Message so you can get in touch with the Mod team for help with this if needed. We are quite busy at the moment so it will take a few days to get back to you.
Cheers
John
Message 3 of 3
Thanks for sending over the details @BJ2023 .
I'm really glad to hear you're connected. Post back if you have any other problems and we'll be happy to help.
All the best
David
