Message 11 of 16
Re: Internet dropping out frequently
Also to confirm yes I am connecting wirerlessly. And there is no where I can connect an ethernet cable with the BT hub that I can see.
Message 12 of 16
"The hub is connected via wireless via the ADSL connector. There is no where for me to plug an ethernet into the wall. "
The hub must be connected via a cable to the wall socket - it can't be connected "via wireless".
As the light on it stays blue, this confirms that you have a stable broadband connection at the hub.
It sounds like your computers, phones etc then connect to the hub via WiFi and the dropouts you are experiencing must be due to some sort of fault with this - or an interference with the WiFi signal.
As has been suggested, try connecting a computer by ethernet cable to one of the yellow sockets on the back of the hub. If that gives you a stable connection then that will prove that the dropouts are due to a problem with your WiFi - or possibly a WiFi issue with the hub itself.
Message 13 of 16
Thank you. However I don't have a laptop or phone that can be connected via an ethernet cable. All my appliances worked perfectly well with Vodaphone only a few months ago. So fault is absolutely with BT  Is there anyone on the forum that is able to elt me know how I get the hub replaced? Also given I've not had a working internet since joining is there any advice on how to get a refund? Thanks
Message 14 of 16
As I and @chrisjp  posted as your hub lights remain blue that suggests your internet connection is working as it should and the problem is the WiFi connections.  Have you tried changing the wireless channels in the hub and best using a WiFi analyser in your phone to see channels in use then select a free or less congested channel in the hub turning off auto.
You can also try a different mode instead of default 1 so maybe2 or 3
Message 15 of 16
Hi I've tried switching to mode 2 in the internet settings but it has not made a difference 😞
How do you change wifi channels and use a wifi analyser. It's probably worth me mentioning I am not a BT hub tech expert...
Message 16 of 16
Just get WiFi analyser on your phone from app store then search and you should see the WiFi channels in use near you including your own. You want to select a channel least used. Then go to hub manager then advanced settings then wireless and then change the channel to the one you want and then save as you exit
