Message 11 of 13
Re: Is BT missing out?
Starwire.
And when this happens, or the service deteriorates, are you saying BT will say tough, you made your choice…..
Message 12 of 13
No, they just know you’ll come crawling back.
Message 13 of 13
I can’t see many crawling back.
It is impossible, at this stage, to predict how connectivity will evolve.  If  your prediction becomes fact I, and I expect the majority, will evaluate options and make a educated decision.
In the meantime keep looking in your crystal ball. If mists clear and you see the result of Sundays match, keep it to yourself.
